NC solenoid valve is always open with water
KarolR
IL
NC Mec-Fluid2 MF-B0829 solanoid valve is O.K. with air (i test it with my mouth), and passes tap water regardless of current.
I open the water tap slowly, the solanoid passes the water immediately, even at the lowest stream. i them energize the coil-a slight stop and the water continues to flow through the valve.
It doesn't become NO, it just doesn't react to current.
Then it's broken.
Get another one.
