Contact US
Cracked Gas Compressor Active Thrust Temp Increase
2 weeks ago our active thrust temperature increase above normal operating range by +10F. Normal active thrust bearing temperature roughly 192F. This is on the first of three stages. Due to the service, we inject a total of 1.08 GPM of wash oil & 13.35 GPM of condensate for fouling purposes. This ratio keeps us under the rule of thumb of 5% of total flow going through the machine being liquid (at the ratio, 4.8% is liquids).
On the attachment, you can see that on 5/14 active thrust temperature increase above normal operating range by +10F (Axial vibration increased 1.6 mils). 5/17-5/20 we had severe weather conditions with active thrust temperature reaching 210F. Days after the temperature & vibration decreased significantly. for the past seven days the temperature & vibration have return to normal operating conditions.
Attachment: Red=Vibrations, Purple=Temperature
My question is why for the excursion? All data leads to the balance piston. Leading to my next question, are we fouling or experiencing wear on the balance position? My thoughts if we were experiencing fouling, the machine would thrust toward the inactive bearing. IF your were fouling or seeing excessive wear, woulding you see it over time? Thanks in advance.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
