Intze tank design
Intze tank design
Hello ALL
I am designing the Intze Tank by conventional Method. while designing i am considering the junction of Column, Main Ring Beam, Bottom Dome and conical dome as monolithic structure. As the reinforcement of column to be extended in Beam for the moment transfer, the junction considered as monolithic in construction. IS it correct to consider the junction as monolithic?
