Vacuum pump head vs atmospheric pressure
Boiler1
IE
Why would the vacuum pump available head depend on atmospheric pressure - i.e. lower the pressure, lower the pump head. If the pump is discharging at the atmospheric pressure can it not create any vaccum on the suction side? Why doesnt such a thing affect the compressors?
You need to add more to your question here so that we ( I at least) can understand your question.
atmospheric pressure has an impact on lots of things, but I can't work out what your question is.
You're right! the question is all over the place. Essentially, when the atmospheric pressure drops my system has to start a back up pump in order to maintain the vacuum set point. I assumeed my theoretically feasible vaccum must be somewhere between 0 and the atmospheric pressure. Cant understand is it possible to have a vacuum in the system that is higher than the atmospheric pressure. Say, if the atmospheric pressure is 1bar/750 Torr is it possible to maintain 1500 Torr in the piped vacuum system?
This description helps clear up why atmospheric pressure dictates vacuum performance:
Article said:
Vacuum at high altitudes
Atmospheric pressure determines the maximum vacuum force that can be achieved. And standard atmospheric pressure at sea level is 29.92 in.-Hg. But what happens at locations a mile above sea level? The maximum vacuum that can be achieved in locations above sea level will be less than 29.92-in.-Hg. The force will be limited by the ambient atmospheric pressure. Vacuum pumps have maximum vacuum ratings based on sea level conditions and must be re-rated for operation at higher elevations.
First, determine the local atmospheric pressure. A rule of thumb is that for every 1000 ft. of altitude above sea level, atmospheric pressure drops by 1 in.-Hg. Using rounded-off figures, for a city at an elevation of 5,000 ft, the atmospheric pressure is about 25 in.-Hg.
To adjust a pump rating, think of that rating as a percentage of atmospheric pressure at sea level. If a pump is rated for 25 in.-Hg, it can achieve 83.4% (25 29.92) of a sea level perfect vacuum. At a 5000-ft elevation, that same pump can achieve 83.4% of 25 in.-Hg - or a vacuum of 20.85 in.-Hg.
Boiler 1.
I can only assume your system as you refer to it as a vacuum system is less than atmospheric pressure.
Hence it would be less than 750 torr in your example.
So 1500 torr would be 1 barg or 2 bara, i.e. MORE than atmospheric pressure
Your vacuum pressure sensor / measurement is likely to be a differential sensor so it it actually measuring the difference between atmospheric pressure and your system. Hence if the atmospheric pressure goes down then the difference goes down and it triggers the vacuum pump to operate.
I'm still not really understanding your question though... [ponder]
