Anyone know hpw to show the checking of member which shows bending moment, bending moment capacity , shear , shear capacity, axial force acting on member, axial capacity of member in one page like ETABS ? I used STAADPro to design some steel structure, unfortunealy some bracing failed, the utilistaion ratio > 1, however, it doesnt show what cause the beam to fail ? Axial ? Shear ?
When I clicked on the member , here is what it showed only , I am not sure what failed and the capacity of the member also. This is annoying.
