Steel Pipe to Concrete Manhole Connection
DPBD
PH
I'm currently reviewing a project which involves a large diameter Steel Pipe drainage with a series of concrete manhole for every certain distance. Is there a good reference for the connection of a Steel Pipe to Concrete Manhole which could also address water proofing the connection? Are Waterstops or gasket sealer effective with this type of connection? Thank you!
