Cryogenic Testing on Check valves
Rituv
Materials
AE
I have few queries regarding the Cryogenic testing on check valves,
1. can Cryogenic test for Swing and dual plate check valve be achieved @-40 degree c, Material of the valve is A352 LCB.
2. can Cryogenic Check valve tested for High pressure gas test?
3. At which temperature for cryogenic valve should be Hydrotested?
4. If we all follow BS6364 std. can we achieve all the above, please advise.
