Contact US
Grounding of sub-transmission insulator bases
RUS says if you have a ground wire running close by horizontal insulators, you should tie in the bases to prevent RFI. Is there any reason to tie in the bases of suspension insulators that are not so close to the ground wire? What's your practice? 69 and 115 kV. Thanks.
RE: Grounding of sub-transmission insulator bases
At 115 kV on wood poles we bond any hardware separate by less than 1 foot to prevent pole fires. I had not heard of bonding insulator bases to prevent radio frequency interference.
On a slightly related note, loose suspension hardware can cause RFI. One situation that can cause loose hardware is spans with uplift.
Bacon,
You've heard of it now. See RUS 1724E-200 page 8-14. Makes sense from the pole fire perspective too. Consider an H-frame with suspension insulators with no uplift, though. No bonding here?
Thanks for the link. If the H-frame crossarm is conductive, it may need bonding where it attaches to the pole.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
