Contact US
Capillary tube
Capillary tube
Capillary tube
can you please ellaborate on topic of ordinary capillary tube
In particular, I am interested in bubble entering the tube
Thanks in advance,
lukezo
RE: Capillary tube
Get a copy of a thermodynamics textbook and look up the subject of refrigeration and air conditioning which will detail the function of capillary tubes and the analysis performed on capillary tubes.
RE: Capillary tube
I suspect that your interest is in refrigeration and air conditioning equipment in which capillary tubes play an important function. Bubbles entering a capillary tube will be under high pressure and as the bubbles travel inside and exit the capillary tube, they will increase in size due to the pressure reduction and also the bubble temperature will get colder. When you study the relevant chapters in a thermodynamics text book you will come across terms such as enthalpy, entropy, quality, specific volume, saturated liquid and vapor lines, saturated and superheated region, and much more so be familiar with those terms. It is also important to study the Mollier diagram of the fluid in which the bubble appears and pay attention where on the Mollier diagram the attributes of the fluid travelling through the capillary tube are located.
RE: Capillary tube
Just think about the difference between trying to drink milk vs. whipped cream through a straw.
RE: Capillary tube
What requires bigger pressure difference in your opinion?
I prefer tea
RE: Capillary tube
The evaporator load and condenser load control the pressure drop.
The pressure drop determines the bubbliness.
The bubbliness determines the density.
The density determines the mass flow.
The mass flow determines the evaporator and condenser load.
Repeat.
RE: Capillary tube
I'm asking solely from capillary tube point of view as an element of cooling cycle
RE: Capillary tube
What requires bigger entry pressure? REfrigerant with bubble or with no bubble at all?
RE: Capillary tube
It depends on the exit pressure.
Capillary tubes are all about pressure difference.
The refrigerant cycle is..... a cycle.
You need to think about it as a cycle. If you think about individual points in isolation you will fail to understand how it works.
RE: Capillary tube
The question refers to the change of condenser load. So if evaporator pressure and inlet and outlet stay same, how does subcool / bubble presence before capillary tube influence pressure of condenser? Obviously the pressure will change...
RE: Capillary tube
It is impossible for some things to "stay same" while other things change within the refrigerant cycle.
Everything is connected. If one thing changes everything else must also change to maintain the overall system balance.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
