Vacuum in Solidwork Simulation
JTLim
SG
I am trying to simulate Vacuum in a Carbon Steel Box with a hole at one side and wrapped inside a rubber plastic bag .
I have tried several times but the result showed otherwise as the plastic did not wrap or vacuum, the plastic bag will follow the shape of the box which is a semi sphere shape after atmospheric pressure is applied.
From my understanding, it is something to do with the contact set between the bag and the surface of metal box. Or may I know is it possible to simulate this kind of scenario?
