Manufacturing Management Software Recommendation
My company is looking for a way to streamline our testing and data logging process. Right now when we have a finished product, we will have a technician go through a testing checklist to verify the product meets the specification, then a chief engineer must approve the test parameters before the product is shipped. But we are using a process where the technician needs first to go ask an engineer for the checklist, the engineer will go into our company's outdated system to check options/add-ons for that product and create a checklist from a template. The checklist is printed and given the technician for testing. After everything, the data can only be stored in our local server by manually put into a excel file.
I'm looking for recommendation for some kind of low-code platform that perhaps can assign each product a QR code so the technician can simply scan the code and pull up the checklist with a tablet. After he completes the checklist, the parameter can be sent to engineers for approval and stored digitally.
RE: Manufacturing Management Software Recommendation
Mike Halloran
Corinth, NY, USA
Project checklists are not the most exciting thing on earth and it should be prepared before design and manufacture begins. I suggest you to use QA templates and a checklist to complete the process.
Github and Maven are also two good free testing tools which you can customize and work on.
Hope this helps!
Sarah
