estimating sealing force
Ivan Silva
Industrial
BR
Folks, I've been surfacing on the internet trying to find any guide line on how to predict how much force is required to seal an device with o ring. The matters is I need to design a pneumatic cylinder to exert the desired amount of force to seal the device but everything I find until now is the force per linear inch data... Someone could gently help me?
You mean by the perimeter? I have been thinking about it. It's works just like an spring? Could I use the Hooke's Law
What would you use Hooke's Law for in this case?
I don't know if it's right but by what IRstuff said and the unit of force per linear inch data range (pounds per inch)I've deduced that Hooke's Law could be used...
It's like estimating how much the o-ring weighs based on the weight per linear inch, not on the deflection, which isn't mentioned. Makers of o-rings publish the required force to establish a seal for each cross-section on a per-linear-inch for each material, so the length * force-per-linear-inch gives the force required. The o-rings are compressed a fixed amount.
I think it depends on the hardness. The best is to test the o-ring in the groove until the flanges come to the face-to-face contact.
Some of the manufacturers can probably give you guidance about the force required.
In the large flanges with o-ring seal the sealing forces mainly ignored since it is to low against the tightening for pressure.
For preliminary estimate you can follow hydtool’s recommendation. However the Parker guide does not give how these graphs derived, in/out of grooves, with/without back-up rings. Elastomer o-rings can change their shape, fill the cavity they are in under pressure. There are large number of factors for the pressure loads which may effect the friction force.
In case you are designing one or two cylinders for special purpose the guide above is sufficient. If you are targeting to reduce or find the exact piston driving force required for large number production you need perhaps do the test, document it and convince yourself.
