IdanPV
- Aug 26, 2019
- 497
Hello All,
I would like to know if there are any special requirements regarding the location of the pressure relief valve which is to be installed in a ASME VIII-1 vessel.
This is a rectangular vessel which designed to contain steam, due to design considerations, I would like to install the relief valve on one of the vessel walls (left side or right side) and not on the top of the vessel.
Is there any requirement in the Code which prevent me to do so?
Thank you all
Thank you all
