Contact US
Large diameter pipe with small extruder?
I'm wanting to make some long lengths of large diameter pipe around 450mm dia with a 28mm wall. I only have a small extruder and the die making company says it's not possible. My extruder has a motor of 10hp and I'm not sure of the output capacity, but am assuming close to 100kg/hr. I'm wondering the reason that it's "not possible" I don't care if it is really slow.
My calculations show that it should be able to make at a rate of around 2m/hr. Is it detrimental to have the plastic move through the die too slow and keep it at high temperature for so long? Is there not enough back pressure? I'm fairly inexperienced with extruding and am keen to learn a lot more.
Thanks in advance for any thoughts.
RE: Large diameter pipe with small extruder?
You can make the pipe as a 3D printer would. Extrude a bead as you rotate the pipe.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
