Dear Sirs,
Is it possible to partially left a Tank to replace part of the corroded bottom and annular plates?
Moreover, is it true that the malfunction or torn CP grid system can not be replaced or repaired when a leak detection system installed under the Tank and the CP system was also provided between the barrier and the bottom steel?
