Software recommendation for Steel Special Moment Resisting Frame?
jacky89
Any design software recommendations for special moment resisting frames? Preferably simple to use modules like the ones in Enercalc or Tedds. Spreadsheet software would be even better. This is mainly for 1 to 3 stories residential construction.
I found Engineering International spreadsheet but it is not a comprehensive moment frame design and you can't even enter the lateral seismic load.
Thanks in advance!
