Contact US
CAT EMCP 11+ to Deepsea MK11
Guys,
I have a CAT Generator and would like to switch the controller from EMCP 11+ to a Deepsea.
How can I achieve this?
RE: CAT EMCP 11+ to Deepsea MK11
DSE has many controllers and some of them will work with pre-J1939 systems. Have you tried to reach out to DSE? They should be able to guide you in the right direction.
https://www.deepseaelectronics.com/genset
What type of fuel injection system you have? EUI( electronic engine) or MUI (mechanical engine)? when you provide this information we can better assist you.
Short answer is yes, can be done.
More details about your existing unit would help define what you actually need to do.
An MUI engine is a much easier retrofit, as the new controller can pretty much do everything to EMCP II did for it, but you will likely need to add a jacket water temperature and oil pressure sensor compatible with the new controller to get those functions back.
EUI units a bit more complicated but really not much, you will probably need to add a 4 position engine control switch (you can take the one off the EMCP) to give the engine ECM the right mode inputs. You will also need to to look at what protections were provided by the EMCP II and what is active in the engine ECM, engine protections such as JW temp and oil pressure was left to the EMCP II on older EUI engines, newer engines pretty much took care of all engine protections and crank functions in their ECM's, with the EMCP II interfacing by CAT Data Link (CDL).
Hope that helps, MikeL.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
