Contact US
Does presence of H2S> 50 ppm in Pumped fluid require use of Double Mechanical Seals
I am doing a preliminary seal plan selection for various API 610 pump services. In the Client Specification for mechanical seal, i find a note for Foul Water service i.e. "H2S concentrations greater than 10,000 ppm requires dual seals". I have got foul water services with H2S concentration in the range of 400 to 2600 ppm.
I found another article by EagleBurgmann, where i find Single Seal w/Plan 65 for leakage detection if H2S concentration in pumped fluid <50 ppm and double seals i.e. Plan 52 up to 1000ppm (w/buffer liquid being changed on monthly basis) & Plan 53 above 1000 ppm is recommended.
So, how do we come to the conclusion if a double mechanical seal is required?
RE: Does presence of H2S> 50 ppm in Pumped fluid require use of Double Mechanical Seals
Follow the client's specification.
Good one bimr. Dont have to Google that.
Agree with BIMR  The client have give you the specification of their process requirements
horacio
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
