Lowlyslows
New member
Hello!
New to the site, not sure if I am posting in the right location or not.
I am trying to figure out what to do with an automotive lift install for my garage.
My slab is 4" thick, 3500psi, with structural grade beams and wire mesh. The instructions for the lift calls for at least 4.25" slab thickness, 3000psi, and steel bar reinforced concrete. So, I don't meet the minimum requirements. The lift can support up to 6,000lbs.
I spoke to an engineer yesterday. He doesn't like the idea of me just putting the lift on what I have. My house is a walkout and the garage is attached on the side. When they built the foundation (2018), they dug down to pour the footers which are about 8-9 feet below the concrete slab in the garage. Then they backfilled the garage and didn't compact the soil. The slab is supported by 4 concrete beams going across the garage (horizontally and perpendicular to the garage door entrance). So, if I open up the concrete to get a thicker slab, I have to do it between the beams, engineer doesn't want me touching the beams. That's not a big deal through careful measuring. My issue is the soil, solid earth starts around 8-9 feet down so I got to figure out how to get to it to support the lift. This is coming from the engineer.
I'd like to get some opinions from anyone willing to give them on what to do here. Lots of other guys just cut out a section of concrete and dig down a bit a pour new concrete. None talk about the support required by the soil.
I attached a power point of what I am working with, pictures, and some ideas the engineer and I talked about. Any help is greatly appriciated.
-Paul
-Paul
