Magnetism in pipeline
Dear colleagues,
I wonder about the possible techniques to overcome the residual magnetism in a pipeline during welding!
By the way, from where that some underground or above ground pipes become magnetized?
Thanks for your continuous support.
Best wishes,
RE: Magnetism in pipeline
Pipe can become magnetised usually by storage with a North-South alignment with the earth magnetic field, or parallel alignment and close proximity to HV electric power lines. Earth Magnetic fields are not always north-south, so check a magnetic compass and store pipe with an East-West alignment. Store pipe as far away from HV lines as possible and always perpendicular to the line itself.
Lots of suggestions how to demag here,
https://duckduckgo.com/?q=demagnitize+oipeline&...
Look up "de gaussing"
I've seen welders wrap their cables around the pipe(s) when welding to generate a magnetic input to prevent the arc from going sideways, but not sure how effective that is.
Not usually too difficult to de-magnetize pipes though.
By wrapping cables and pulsing current in decreasing increments in reversing directions does work well.
AC demag is usually easier and better. Sets are made to do this.
Just a point of clarification. Your issue is with magnetization. All steels are ferromagnetic and that part cannot be changed. They do very a lot though in how much field they can retain when they are magnetized.
Thanks all for the above discussions.
I would like to know exactly which cables negative? grounding cable? to wrap around? and at what distance from the welding grove? and how many wraps required? and how to reduce the current?
Can we have clear steps that have been applied and succeeded using DC equipment?
Best regards,
That link by saplanti gives you most of the answers. Any experienced pipeline welder should have seen this before and is in control of current and can see the weld arc.
Or if that doesn't work, maybe this,
You can try this link for an article on demagnetization:
https://www.nxtbook.com/nxtbooks/aws/it_202005/ind...
There were several posts on this subject right here. A quick google search will provide the links.
Best regards - Al
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
