Contact US
Copy NX file in TeamCenter to existing Teamcenter file
Is it possible to save as an NX file in TeamCenter to an existing file in Teamcenter?
For example I want to save
the NX file (drawing and everything else) in Teamcenter MM12345/3 To MM98765/4 in Teamcenter
(the main file is in Rev 3 and the copied file is an existing Teamcenter number in Rev 4)
Jerry J.
UGV5-NX1884
RE: Copy NX file in TeamCenter to existing Teamcenter file
It should be ,depending on your NX / TC Versions , and, if the Teamcenter is set up to allow this. ( the action is Save as xyz- something, blocked here.)
- but, it might be easier to cheat... smile
In Teamcenter, things are not what they appear at first glance,
I Assume that you have Items and Item revisions and under that you have "the files". ?
These "files" are "datasets" and not files, each contain multiple files and or meta data in some way.
You can ( hopefully) right-click the NX model dataset and see "Named References" ?
Select that and you should see several files and some other things such as preview etc , AND the actual NX file.
The cheat is that one can export and Import to these "Named references" . But, if you are about to replace one part in one dataset, keep a copy , and ,
try this method on some test files first..
Notice that to delete a file from a dataset,. you need to check it out first.
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.smile
Thanks Toost, I know most of the ways to "cheat" in NX, but TeamCenter always throws me a curve.
Jerry J.
UGV5-NX1884
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
