Buoyancy driven flow
Lukezo
30
Hi people,
I'm about to model flow of air inside a vertical tube with air inlet at the bottom of tube about a feet away from bottom. The air gets moist and warm inside tube.
Can you ellaborate on boundary conditions?
2. Which is the appropriate outlet condition?
How does the air become warm and moist in the tube?
By spraying hot water into air stream.
To simplify, plan is to implement udf connecting air velocity and temperature before moisturizing section.
