How to suppress phi symbol in AutoCAD LT dimensions?
The drafting standard where I work doesn't use the phi symbol in diameter dimensions and I'm trying to find out how to remove it from a dimension in AutoCAD LT.
RE: How to suppress phi symbol in AutoCAD LT dimensions?
Type the command DIMSTYLES and go looking for the prefix used for DIMDIAMETER
Use DIMLIN instead of DIMDIAMETER (poor practice)
Use DIMRAD using a special style that multiplies the dimension value by 2X (very poor practice)
Please remember: we're not all rednecks!
www.sparweb.ca
in the dimension style definition: put a blank space in the Prefix box.
Spar, here, radial dims are <dim> R, diamteter dims are <dim> DIA, I don't make the rules.
