Can anyone please advise on domesti
Can anyone please advise on domestic calculations. I am looking at dormer calculations and want to know if it is acceptable to support a ridge beam on the existing chimney breast (via a padstone) similar to the image below
My understanding is that this not allowed due to potential deformation of the steel due to heat within the Chimney. However, are there also structural implications?
I have also seen designs where a bracket is fixed to the Chimney Breast and where the ridge beam is supported by a steel post .
Many Thanks in advance.
RE: Can anyone please advise on domesti
are you in a seismic area?
how thick are those brick walls, how tall, and how old?
No seismic. Walls are likely 1 brick thick, 102mm and say 90 years old.
are you an engineer? sounds dodgy
DTC87_2:
It is usually kinda tricky placing new large concentrated loads on old masonry chimney structures. It takes some serious engineering experience and judgement to make this work well, if at all. Usually, chimney structures are intended to support and confine fireplaces and their chimneys, and any leaked sparks and the other products of combustion. They are not (or have not been) designed to take other structural loadings. They are very heavy on their own footprint and might settle differently than the rest of a lighter framing system. Thus, they are usually built independently of the rest of the structure, except that they may laterally support each other and be conjoined at the foundation. Furthermore, there are fire rating issues with supporting structural members on and into the chimney structure. It is really not a matter of the chimney heat weakening or deforming any structural members. Those magnitudes of temps would indicate a real serious chimney defect. Building codes are usually quite specific about clearances btwn. chimney structures and the remaining bldg. framing and any allowable support of structural framing on the chimney. The fact that you see some instances of structural bearing on chimney structures does not make it code compliant. It just means that they got away with it and that the structure has probably never seen the code max. loads either vert. or lateral. Lots of things seem to work under normal conditions and circumstances, which do not take full account of public safety which is required by the bldg. codes, which we must design to meet.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
The Great Project Profitability Debate
A/E firms have a great opportunity to lead the world into the future, but the industry’s greatest asset—real-time data—is sitting wasted in clunky, archaic ERP platforms. Learn how real-time, fully interactive dashboards in a modern ERP allow you to unlock data that will shape the future of the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
