FM200 duct dampers for sealed enclosure
Hello everyone!
Several type of ducts are passing in the ceiling of a room protected by FM200 system as follow:
1-Supply duct to the space
2-Return duct to the space
3-Fresh air duct to the space
4-Exhaust air duct to the space
5-A series of ducts that are crossing the protected room walls to serve other areas (without having a supply or return grill inside the protected room with the FM200)
-The motorized damper should be installed at the duct when penetrating the protected room for all the duct mentioned above (point 1/2/3/4/5) or it must only be installed for point (1/2/3/4)?
-As well the motorized damper must be a motorized smoke fire damper? or can be a normal motorized damper?
I already try to search in the NFPA 2001, but i was not able to find a reply.
Thank you very much for your help :) :) :)
RE: FM200 duct dampers for sealed enclosure
First question are any or all of the walls rated??
the walls are not fire rated for some spaces
but other spaces (having a with similar situation of ducts crossing the walls and protected by FM200)have fire rated walls
so i have the 2 options :D
thanks
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
The Great Project Profitability Debate
A/E firms have a great opportunity to lead the world into the future, but the industry’s greatest asset—real-time data—is sitting wasted in clunky, archaic ERP platforms. Learn how real-time, fully interactive dashboards in a modern ERP allow you to unlock data that will shape the future of the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
