Contact US
Automatic curve generation in HyperGraph
Hi, guys!
I want to build multiple curves automatically in HyperGraph through secondary development. But I find that the API command "pltIBuildPlotsCtrl GenerationPlots" doesn't seem to be able to generate curves. Please help find the reason. The core codes are as follows:
set t [clock click];
hwi OpenStack;
hwi GetSessionHandle sess_$t;
sess_$t GetClientManagerHandle mgr_$t Plot;
mgr_$t GetBuildPlotsCtrlHandle build_$t;
build_$t SelectDataFile "E:/CalculateDynamicStiffness/subframe_front_E90000.pch" false;
set subcaselist [build_$t GetSubcaseList];
set xDatatype {Frequency [Hz]};
set yDatatype {Displacements};
foreach subcase $subcaselist {
build_$t SetSubcase $subcase;
build_$t SetXDatatype $xDatatype;
build_$t SetYDatatype $yDatatype;
build_$t SelectYComponents {"MAG | X-Trans"};
build_$t GeneratePlots;#This command is invalid!
hwi CloseStack;
The return value of each command is 0 or a string. Thanks for your help!!!
RE: Automatic curve generation in HyperGraph
I have solved this problem. It is the API command called "Recalculate" to realize the "Apply" function. By it, I build desired curves successfully. The core code is as follows:
set pch_filename "E:/CalculateDynamicStiffness/subframe_front_E90000.pch";
hwi OpenStack;
sess_$t GetProjectHandle proj_$t;
proj_$t GetPageHandle page_$t [proj_$t GetActivePage];
page_$t GetWindowHandle win_$t [page_$t GetActiveWindow];
win_$t GetClientHandle plot_$t;
plot_$t AddCurve;
plot_$t GetCurveHandle curve_$t [plot_$t GetActiveCurve];
curve_$t GetVectorHandle xvec_$t x;
curve_$t GetVectorHandle yvec_$t y;
xvec_$t SetType "file";
xvec_$t SetFilename $pch_filename;
xvec_$t SetSubcase 0;
xvec_$t SetDataType "Displacements";yvec_$t SetType "file";
yvec_$t SetFilename $pch_filename;
yvec_$t SetSubcase 0;
yvec_$t SetDataType "Displacements";
yvec_$t SetComponent {MAG | X-Trans};
plot_$t Recalculate;
plot_$t Draw;
I still can't realize the function of automatic output curve through “pltIBuildPlotsCtrl Class” and wealth. But through the pltICurve Class, I realized the function I wanted, the code is as above.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
