TRUMATIC L3030 - 3000W - problem with PLC - inquiry
bencaha
Computer
CZ
we have a trumpf machine L3030 - 3000W. I reset the Siemens 840D according to the manuals and instructions. He played from the NCK machine and then the PLC.
I refurbished one faulty servo. Restored the system from backup - functional.
The laser writes the following two errors after approaching:
1.)
F29.03.21 12:56:30 PLC (80.102000): The machine dautm 15101 is not defined
2.)
29.03.21 12:52:05 PLC (07.000000): Feed pot is situated at 0
When connected to the 840D, I see everything OK, both the memory and all the modules and the system time fit.
It does not make any sense.
Does anyone have this laser PLC and NCK data? I have several versions and the error is the same.
Isn't it possible that some memory has gone?
Thank you.
 https://files.engineering.com/getfile.aspx?folder=cdd17ffa-99fd-495d-9c0e-f53590839d2d&file=trumpf1.jpg
