How do I extract the second moment of area being calculated by an I profile
I want to confirm that the second moment of Areas being calculated by Abaqus for a I profile matches my calculation. I am aware query allows us to see the moment of inertia about the center of mass but that value does not match, because I am assuming it is in regards to the mass of the element and not the area. any direction is helpful
RE: How do I extract the second moment of area being calculated by an I profile
To calculate section properties in Abaqus you can do this:
- create a 2D part and draw your section, then mesh this part with plane stress/strain elements
- assign material to the part
- add the part to assembly and create some analysis step (for example general static)
- write the input file and edit it:
* replace the type of elements with WARP2D3 (triangular) or WARP2D4 (quadrilateral)
* replace the step with *Beam section generate
Run this analysis and you will get a .bsp file with section properties for your geometry.
You can find more details about this procedure in the documentation chapter "Meshed beam cross-sections".
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
The Great Project Profitability Debate
A/E firms have a great opportunity to lead the world into the future, but the industry’s greatest asset—real-time data—is sitting wasted in clunky, archaic ERP platforms. Learn how real-time, fully interactive dashboards in a modern ERP allow you to unlock data that will shape the future of the world. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
