Peak Friction Angle
Peak Friction Angle
Hello All,
The angle of friction that we get from the Mohr's circle envelope of a CU test, is that the peak friction angle?
RE: Peak Friction Angle
There are also undrained relations, which is a different topic.
The nature of your question is the basis why the ASTM standard for shear strength testing of soil excludes the preparation of the m-c envelope.
f-d
ípapß gordo ainÆt no madre flaca!
Otherwise, yes, it's the work of an engineer. And, engineers should consider strain compatibility.
f-d
This is all documented in a CGPR (Center for Geotechnical Practice and Research) publication from 2015 or so. I attended along with Tim Stark, Tom Brandon, Steve Wright, Mike Duncan and many others. (I studied at VT and have been involved with CGPR for quite a spell.)
Nice to see folks getting into these weeds.
f-d
Working in slope stability projects compression tests results are very common to see but understanding the failure plane through a clay layer is typically horizontal the results from direct simple shear testing are more applicable and will show lower shear strengths than compression tests.
We have used the direct shear test results on remolded samples before on projects but we did not use that test on the current one. I will go through the CGPR publication that fattdad mentioned.
I read somewhere that undrained strength of clay varies with the orientation of the failure plane. Hence I think the comment from geg. But can we say the same for drained strength. I don't know. can you shed some light?
The shear surface of the DDS is constrained; however. However; FSS at low normal loads renders this matter trivial.
f-d
Can you explain, please.
Thanks.
So, if the peak for one load is at 5 percent strain and all the others are at 15 percent strain, the, "Rule" is to strike a line parallel to the initial tangent modulus, but initiate the line at 2 percent strain. That parallel line will strike the stress strain curve at some point. Use that for M-C development.
In this manner, you will solve the strain incompatibility problem. . . and lower your friction angle.
f-d
