Simulink linking blocks
John_Hoekstra
MD
Good day people
I have recently started to make random models in Simulink. I have made a model and I am almost done with it, but I can't get my hydraulic torque linked with my electric torque. I guess it's a stupid question. Does anyone know how to solve this?
In the last part, I factored the flow and the pressure with each other and divided them with the angular speed.
Thanks in advance
Albert
 https://files.engineering.com/getfile.aspx?folder=efae6805-38eb-4cf4-821f-f53a1f3798e9&file=VFDDRIVECOMBINED.slx
Greetings. Didn't see your entire schematic as an older version of MATLAB (the preview is also difficult to parse), but I assume you are using Simscape. Therefore, in this case, try converting the physical hydraulic signal to a Simulink-signal, and then again to a physical electrical signal. For this, use the blocks as shown in the picture in the appendix.
 https://files.engineering.com/getfile.aspx?folder=4f12692a-c947-4c3c-bee0-3317e9d09187&file=Image_PS_SP.JPG
