NXOpen Dev to update all measure in NX12
PSI-CAD
Computer
Feb 13, 2009
997
Find herewith a part to explain the bug in NX12
Open the part
Have a look at the content and associative points and datums
Change user expression move_face from 1 to 2
Check that the point and datums are not correct
Apply filter dimensions on the ANT
Then edit all dimensions one by one
Then check that points and datums are correct now
This bug is corrected in NX1953, but my customer stay in NX12 at the moment
So, I need an NXOpen programm to edit all dimensions.
I started with the following lines to list all the measures
For Each tempFeat As Features.Feature In workPart.Features
If TypeOf (tempFeat) Is MeasureMaster Then
lw.WriteLine("Measure name: " & tempFeat.GetFeatureName)
End If
Next
Now, I have to find all parents of each measure to be able to create the edit builder
Thanks in advance for your help
Didier Psaltopoulos
I've been meaning to look into this, but it has been a busy week. I think that a journal could be made to update all the measures as you suggest.
But first, I'd like to mention an alternative:
In the measure command, you can turn on the "create associative geometry" option. This will create an associative line between the measure points. The end point of the line could be used instead of creating individual points. A bunch of lines will clutter up the display, but they can be moved to an invisible layer. These lines (and the associated datum axis) do update correctly when editing the user expression.
www.nxjournaling.com
Hi Cowski,
Thanks a lot, it works well, but I need to create again all my measure because, it's not possible to create associative line after.
Didier
Didier Psaltopoulos
