Flushing EP2 grease from 1/2" OD x 0.083 WT tubing lines
Is it possible to flush and remove EP2 grease from 1/2" OD x 0.083" WT tubing that's already installed in place? This would require flushing through bends as well as tube fittings. I have serious doubts that this can be done but wanted to pose the question anyway. I appreciate any input on the matter.
RE: Flushing EP2 grease from 1/2" OD x 0.083 WT tubing lines
