the pressure suddenly drops in the LNG storage tank and the same in the suction flow of the tank vapor recovery compressors
the operating conditions before the incident:
the load of LNG received at the level of the tanks is heavy compared to the load stored in the tanks it contains less nitrogen
a cargo ship
takes place 5 hours before the pressure drop incident
note: after each ship loading there has been a drop in pressure but in our case the drop takes place just after loading and it reabsorbs a significant value after 5 hours
Is that this pressure drop and the result of the accumulation of the heavy load in the tank more favored by the load or this drop due to another cause knowing that usually we have worked with almost the same load without any pressure drop
thank you in advance for your collaboration
a cargo ship
