Contact US
Progressive stamping press
Someone enlighten me about progressive stamping press. I have done a little research but am unable to find relevant content.
RE: Progressive stamping press
The die is progressive, not the press.
As the press cycles the material is fed from one stage of the die to the next.
Even fairly simple parts are often stamped this way.
You get better control of the final part and it lowers the stresses on the tooling.
First hit bends it a little bit, second hit bends it a little bit more, third hit (perhaps) folds an edge over in a way that you couldn't possibly do without having first done the previous pre-bending stages, fourth hit (perhaps) knocks a couple holes in it, fifth hit (perhaps) knocks it to the correct outside shape and frees it from the surrounding scrap. Or something like that. Could be as many or as few hits as it takes to get the job done.
A customer of mine makes big stampings for the automotive industry, and they've got a progressive line that uses 7 complete separate mechanical stamping presses, each with a different die set, to get the part into the correct shape through 7 successive hits.
Or if you are making little sheet metal brackets or tabs, you could have all stages in succession in tooling within the same press - the feeder just feeds the material through by indexing it the exact pitch distance between stages in the tooling.
More information = better answers.
So, what's your question?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
