Python Abaqus script : "No module named odbAccess"
Tarhouni
Student
Mar 3, 2021
4
My question is around an error on python : no module Named 'odbAccess'.
I have started with these lines :
import sys
import odbAccess
import numpy as np
from odbAccess import *
from abaqusConstants import *
from types import IntType
from numpy import array
For information, this script is running when I use the command Run script with abaqus and the error appears when I run directly with python.
I would be very grateful if you help me to solve this problem.
Thank you
The error is pretty obvious... you're trying to import a modules named odbAccess, but Python can't find it. It's either not in your search path or it doesn't exist.
Dan - Owner
