Help identifying check valve manufacturer
Good day,
I need to identify who is the maker of the bolt check valve in the picture end/or the maker of the valve insert that is screwed with a pin face spanner in the valve body. The idea is to buy the valve insert and service the many valves I have.
The valve assembly screws in the G3/4 discharge port of a Danfoss PAH 32 axial pistons pump. The overall length is 68.5mm and the hex head is 32mm
I can't get help from the equipment manufacturer and I could not get any lead on Google or Parker catalogues.
I really hope someone here has seen it before.
