OEE assets measure at refinery industry
johngladstone
YE
Hello folks ,
Is there any sheet or form use to calculate OEE of Assets and Process in refinery and upstream industry ??
Best wishes
John gladstone
Overall equipment effectiveness (OEE) is the premier standard for measure. is used as a benchmark to compare any given production to industry standards, in-​house. were constantly reacting to unscheduled downtime on certain assets; and the. However, it is also often used in refineries to help identify actual output.
Hi Hill
Thank you
Have you got practical example to calculate oee for pump , heat exchanger , heater and turbine ?
Thank you in advance
R
John
Hi Jessica ,
Is there possible to support me by practical example to calculate oee in refinery application ?
To calculate OEE for pump , heat exchanger , crude oil heater , compressor and turbine ??
John
