double stacked parking
arvind7085
IN
What kind of Live Loads would you have for a double stacked parking ?
I'm not sure what double stacked parking is, but I'd probably double them...
It depends on type..You are expected to ask manufacturer ..And for the parking area, I suspect more than double of the car wt and for the access roads look to your valid loading codes.
I assume a set up similar to following ;
Now I know what it is... added equipment loading... thanks.
