Is there a command that will halt execution of a 'for loop' if the program reaches that point and maintains the variable values? I'm haveing difficulty with the attached program. Using the same function, I get different values inside the loop and outside the loop. The post does not allow me to upload a *.sm or *.pdf, for some reason. Maybe from an edit?
