Bottom Chord of Roof Truss Cut
Hi all,
I am trying to retrofit and reinforce an existing roof truss that had a portion of its bottom chord cut for attic stairs. I am analyzing this truss in RISA and am having some issues with getting a repair to work. I have modeled trusses in RISA and by hand before, so I am confident that my model is done correctly. What I do need help with is some possible repair options. I have tried adding in some additional web members and reinforcing what is currently there and I expected there to be issues because we are basically changing the load path of the truss, but I was note expecting the members and joints to be this overstressed. See the sketch below and you will see the truss that I am dealing with. It is a wood roof truss made of 2x4 members @ 2'-0" o/c with a plywood roof deck, gyp board/drywall along the entire bottom chord, and some plywood in the top of the bottom chord for some storage. Any help is much appreciated. Thank you in advance!
RE: Bottom Chord of Roof Truss Cut
MiTek Roof Truss Repair Details
This way you can reinstate the bottom chord.
Aside that thhe truss will need to be re analyzed with a raised bottom chord in that area and plywood gusset plates for connectors
If they want this cheap, then relocating the stair and reconstituting the bottom chord is the cheapest proposal.
Anyway, thanks everyone for the help and recommendations, I do appreciate it!
Matt
