Question for those familiar with PU seat design
bcfellow
Marine/Ocean
CA
Hi, I hope I have the right sub forum for this.
I'm hoping to gain some insight from those with experience designing/testing polyurethane seats as I am unable to find an answer to this questions. For a simple 'garden tractor' type of seat (molded PU cushion and vinyl cover)and assuming the same composition for foam and vinyl cover, there are two approaches to manufacturing the cover and cushion I'd like to compare: "Pour in Place" vs making the cushion and cover separate. Is one method better than the other for strength/durability?
Back in the early 2000's when those hot rod TV shows were popular, I recall them universally using PU foam blocks and shaving them in to rough dimensions to make the seats. They would bond together different densities for bolsters and such. The cover determined the final shape.
OEM stuff is always moulded and the cover installed later.
For a garden tractor. Separate is likely better for durability IF you make a very durable cover and have decent foam under it. Together seems to be the most common way it's done. I can't recall ever seeing a garden tractor where the cover was separate from the foam.
Many seat cushions have sewn seams, which require sewing the seams on the inside, turning the cover inside out, and then stuffing the cushion it.
TTFN (ta ta for now)
