Thinner head gasket effect on compression ratio
babol2728
Student
ID
I was wondering how exactly does a thinner head gasket effect directly increase the compression ratio of an engine
Compression is based upon area of "free" volume (area not touched by the piston stroke) being squashed by the volume the piston rides through, right? So, reduce the "free" volume (by thinning the gasket)... eventually you get to a "free" volume of zero, which means the piston ride-through volume will have an infinite compression as the piston completes its stroke.
Dan - Owner
And usually so insignificant it's not worth worrying about.
With the head gaskets of today, they are so thin that there is nowhere to go.
Many years ago, when head gaskets were much thicker, it was a common hot rod trick to boost the compression ration with after market, thin, head gaskets.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
