Contact US
Data analysis of asynchronous motor with VFD
I've been doing data analysis of asynchronous motor under load with frequency inverter. I've got active power and current values exported from the frequency inverter (as .xls file) in one second intervals. My question is as follows: do i need to take into account efficiency of the motor, when evaluating output (mechanical) power of the motor? Frequency inverter input data does not seem to include motor efficiency.
Additionally: Frequency inverter used - Danfoss FC102. Also, this is the data that I've got from the technicians on site. https://1drv.ms/x/s!AmAvxaM1dzRcjzF-_sj2_A4EJvZa?e...
P.s As a mechanical engineer I'm somewhat familiar with the concepts of power factor , efficiency of motor, etc, yet I have very little knowledge of VFD's operation and data they provide for analysis.
Thank You in advance !
RE: Data analysis of asynchronous motor with VFD
Are you aware of distortion power factor?
The power factor that we have been familiar with forever is displacement power factor.
This is the result of a phase shift between the applied voltage and the current drawn by the load.
With the growing proliferation of non-linear loads another effect has become apparent;
Distortion power factor.
Distortion power factor is an expression of a ratio between apparent power and real power that is not caused by a phase shift but is caused by harmonic currents.
While displacement power factor may be corrected with capacitors, distortion power factor may be mitigated by filters.
Unfiltered VFD output waveforms are rich in harmonics.
The effect is that the apparent efficiency of an induction motor driven by an unfiltered VFD may be less than the apparent efficiency of the same motor driven by a clean waveform from direct connection to the grid.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
What is your goal here? Are you trying to ascertain mechanical load power requirements via the data from the VFD output?
Most of the time, if a VFD provides you with a value of "Output KW", they have developed an internal algorithm that can calculate that with their known parameters of voltage, frequency, torque and power factor. I don't know if the Danfoss FC02 line is providing that, but they are not a "bottom feeder" type of drive supplier, so I would imagine they do. If you are trying to get there by looking at those individual data points, you may be in for a challenge.
Thanks for the a quick reply. "Are you trying to ascertain mechanical load power requirements via the data from the VFD output" Yes. I'm trying to do that. I'm trying to compare calculations vs measured mechanical power. in other words, how well calculated value correlate with measured results. My idea was to multiply motor efficiency x power value exported from VFD. I understand, that this value won't be 100% accurate (due to reasons mentioned by warossand due to load dependent change in efficiency itself), but it might be somewhat representative. Maybe You have done something similar?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
