Always Learning
Hello - New to this forum.
I am looking for some clarification on 14.2.11.1 2019 NFPA 13
Does 14.2.11.2 (2) mean as long as my light fixture is 2' wide or less and horizontally 1' or greater from the sprinkler deflector I can ignore the spacing requirements of 14.2.11.1.1 which refers you to both Table and Figure 14.2.11.1.
The other question is relating to definition of 2' wide. This would mean a 2'x4' light would not allow you to comply with 14.2.11.2 (2). If using a 2' x 4' fixture that must comply with 14.2.11.1 because of the 4' length of the fixture?
With the advancement of LED lighting there are several 2'x2' LED highbays available that would make installation coordination much simpler for these fixtures since the ESFR heads are installed pretty tight to the roof deck
Thank you for any input.
