Contact US
Heat exchanger
Heat exchanger
Heat exchanger
In the floating head shell &tube exchanger.
Floating chember will be pressurized with shell fluid?
How?
Is there gap b/w tubesheet and she'll?
RE: Heat exchanger
It would be helpful if you let us know the heat exchanger TEMA type. There are many varieties of floating heads. A couple of types which may fit your description are pictured below. In each of these types, there is an inner head and outer head whereby the tube fluid is contained in the inner head and the shell fluid is contained by the outer head. The outer head is what I think you are calling the floating chamber. These types do not seem to rely upon the tubesheet sliding on a gasket and maintaining a seal, nor do they use packing to prevent leaks to atmosphere. I'm not a heat exchanger guy, so maybe someone can enlighten me as to the correct terminology.
Are either of these similar to your heat exchanger?
RE: Heat exchanger
Tema S type which you shown
RE: Heat exchanger
Did my reply sufficiently answer your question?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
