BOLTED JOINT FREE BODY DIAGRAM 2
eli28
Aerospace
IL
I would like to make sure I frew the bolted joint Free Body Diagram correctly?
The motivation is identifying which force act directly on the joint surfaces for friction calculations and local normal stresses.
How are your forces being applied? Here is my free[‑]body diagram of a screw, which does show an external force...
On my drawing, I have labelled enough forces that I can intelligently discuss whether or not that screw will lift off. I ought to show a compressive force between the bracket and the fixed beam.
JHG
drawoh, that's a poor free body diagram. Should not show internal forces.
Ted
Try what where? The link doesn't link to a file.
It's gone... I think this was the file I downloaded... I don't know what happened... it was just there.
 https://files.engineering.com/getfile.aspx?folder=dae6825e-ded3-4450-a317-118d40813948&file=Bolted_Joints_design_n_behavior.pdf
dik
That was an interesting link thanks
ok, I'll ask ... why are you interested in friction forces ? the variation in CoF will make a mockery of any analysis.
friction... bigtime.
@dik ... ??
The tension in the bolt is hugely dependent on the friction... that's why calibrated torque wrenches are contraindicated as a means of checking tensioning.
yes, friction of the nut on the threads ... I thought the OP was looking for friction on the clamped plates.
it's all part of the turkey shoot... I have a couple of papers that address all components... I'll see if I can dig them up.
Hey dik
Thanks for the book, I reviewed it but couldn't find an entire free body diagram in it for comparing to mine.
At least it's a good book, so I keep it 🙂
Maybe mechanical... but, your FBD is not common...
dik - I didn't understand...?
The internal forces are what I am interested in.
JHG
I think it's a bit pedantic to say the diagram posted is not a FBD. It is in balance, it shows the loadpaths, it shows the detail that the poster wants to discern; that's good enough for me.
