Emulsion Interfacial Surface Tension / Shear
TiCl4
Chemical
CA
Can anyone point me to references that address interfacial surface tensions for emulsions, as well as any reference on shear rate vs particle size of the dispersed phase for emulsions?
All I can seem to find is oil/water-type references and measurements. I'm not sure physical or optical tensiometers would work for emulsions; would measuring the surface tension before mixing the two phases (with the surfactant pre-mixed with the aqueous phase) give a representative number for surface tension? Or would the surface tension value change as the two phases are blended?
I'm piloting a process that shears an emulsified non-polar phase to a particular particle size, and knowing/predicting interfacial surface tension is a key component in that scale-up process. Some of the pilot data is odd, and I'm trying to get a handle on the main factors affecting the final particle size.
