I hope the title is enough to understand my problem, I just want that if the button is click, i want to print an image with some text using class,
just like this in the picture below (example print)
This is my Print.vb (Class)
Code:
Public Class Print
Private Shared Lines As New Queue(Of String)
Private Shared _myfont As Font
Private Shared prn As Printing.PrintDocument
Private Shared G As Graphics
Public Shared Str As String
Private Shared PhotoBox As New Rectangle(5, 5, 150, 200)
Public Shared Photo As Image
Shared Sub New()
_myfont = New Font("Courier New",
8, FontStyle.Regular, GraphicsUnit.Point)
prn = New Printing.PrintDocument
AddHandler prn.PrintPage, AddressOf PrintPageHandler
End Sub
Public Shared Sub Print(ByVal text As String, image As Image)
Dim linesarray() = text.Split(New String() _
{Environment.NewLine}, StringSplitOptions.None)
'EmpPhoto = Photo
For Each line As String In linesarray
Lines.Enqueue(line)
Next
prn.Print()
End Sub
Private Shared Sub PrintPageHandler(ByVal sender As Object,
ByVal e As Printing.PrintPageEventArgs)
Dim sf As New StringFormat()
Dim vpos As Single = e.PageSettings.HardMarginY
If Photo IsNot Nothing Then
G.DrawImage(Photo, New Rectangle(PhotoBox.X + 1, PhotoBox.Y + 1, PhotoBox.Width - 1, PhotoBox.Height - 1))
End If
Do While Lines.Count > 0
Dim line As String = Lines.Dequeue
Dim sz As SizeF = e.Graphics.MeasureString(
line, _myfont, e.PageSettings.Bounds.Size, sf)
Dim rct As New RectangleF(
e.PageSettings.HardMarginX, vpos,
e.PageBounds.Width - e.PageSettings.HardMarginX * 2,
e.PageBounds.Height - e.PageSettings.HardMarginY * 2)
e.Graphics.DrawString(line, _myfont, Brushes.Black, rct)
vpos += sz.Height
If vpos > e.PageSettings.Bounds.Height -
e.PageSettings.HardMarginY * 2 Then
e.HasMorePages = True
Exit Sub
End If
Loop
End Sub
End Class
