Contact US
Steel Casing Thickness
We have plenty of standard casing size and thickness requirements for bore and jack, but we are installing some steel casing for gravity sewer under creeks, etc. via open cut. The install will be pretty shallow from a few feet of cover to the crown exposed. My question is, what casing thickness do I need for a 42" or 48" steel casing? I don't think we need to pay for the extra thickness we'd need for bore and jack, but what is thick enough for open cut so that the casing is not "flimsy" (sorry for the non-technical jargon). The casing in the open cut is just to protect the PVC pipe.
RE: Steel Casing Thickness
In most situations, an open cut casing pipe would be designed to support the soil and traffic loads above it. For steel, that would be a flexible pipe design. However, here you may not have any traffic loads except during construction--and your likely construction equipment should have lower ground pressures than road vehicles--but you might have potential lateral loads if creek washout is an issue.
Here is a link to two Mathcad prime 3.0 worksheets that I posted on the PTC forums in 2014 for flexible pipe design for vertical loads: https://community.ptc.com/t5/PTC-Mathcad/Lusk-Flex... The .zip file includes a .pdf version of each worksheet in case you don't have Mathcad.
If washout is a possibility, then you may need some sort of concrete encasement, but what that looks like would be very site specific and I would want input from the geotechnical engineer and possibly a structural engineer. I have only had to do this once and it was about 30 years ago, so the details are a bit fuzzy.
--Winston S. Churchill
Most municipal agencies have standard sizes for sewer casing. The amount of money that you may save by installing thinner casing will be a very small fraction of the construction project.
bimr...
Around here (central California), I don't know of any agencies that provide standard sizes for casing pipes, whether for open cut or for jack and bore. The few times I have done open cut casings, I had to calc the wall thickness myself. I even did an open cut casing for a 12" water pipe that was going to go under a road being relocated by Caltrans (casing went first, then road, then my water pipe) and Caltrans had nothing. Maybe they do now, but in the early 1990s they didn't.
Fred
Quote (fel3 (Civil/Environmental))
The point that I was making is that there is not much savings in trying to skimp on the wall thickness of a casing.
There are many utilities that have stand details on casings. Here is an example:
Standard Details
bimr...
I agree that it's not worth saving a few pennies by optimizing the casing wall thickness. My point was that the agencies around here that I have dealt with don't have a detail like you show. Perhaps it's because they rarely need open cut casings.
Thanks for all the replies.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
