GastonLagaffe
I am currently estimating on a design-build for a pedestrian footbridge that will be installed on the abutments of a (now removed) railroad bridge. The abutments go up to about 30 ft high of stone with vertical faces. I have no information as to when the abutments were built / when the railroad was removed. I would love to go out and take measurements but unfortunately my access is limited by the border closures... From photos, the walls look in good shape so I am not too concerned about degradation.
My gut feeling is that abutments that can support a railroad bridge will be plenty to support a light pedestrian bridge at full live load. However, I would feel a lot better if there were any resources that could support my instinct here. Would you consider acceptable to simply show that the total load on abutments from the pedestrian bridge is significantly lower than the design railroad bridge loads? Alternatively, are there any resources on quick conservative assessments of existing bridge abutments?
PS: My background is much more on the structural side - and typically our pedestrian bridges are far too light for geotech to be a major design consideration. I would however love any recommendations for courses / resources I could use to bring up my knowledge on the basics of bridge foundations.
Thanks!
Thanks!
